Louie Lip'em
- Dec 24, 2012
- 2
Engine starts, idles, and purrs like a new motor. Leave the idle zone and get a quarter of a mile across the lake and it's as if I shut the key off. Motor dies and sometimes I can feel it wanting to stall and I can feather it back to stay running. If not, I have to let it sit for 10 minutes, start it and it runs the rest of the day like new. This may happen twice at the start, then will run fine and never stall the rest of the day. As if the engine needs to get hot to run well.
So far I've replaced; Key Switch, VRO, Neutral Safety Switch, (which was intermittant contact trouble) thought I had it fixed when I found that one! and now rebuilt carbs. To bad I didn't see this site until now. I would have attempted to rebuild the carbs myself. $1160 and now after one season of fishing, this mechanic I use tells me the VRO is bad again. $600.00 plus. For get it. I'm mixing my own!
Any ideas? When I ask the above mechanic this same question. I could see the Evinrude sign behind him through his eyeballs!
Any related problems?
