Pmccraney
- Jul 26, 2011
- 1,734
Quick couple of question for you outboard pros:
For reference, I am working on a 1974 Johnson 85 h/p; Model No. 85ESL74B. I have the original OEM service manual.
I have done a fair amount of searching, but I am posting a thread to try and get a little more guidance. This boat came without any gauges hooked up. Since I will be installing a new water pump and impeller this winter, I would like to install a water pressure gauge so I can get the readings on a new impeller and be able to monitor things better going forward. I'd also like to install a water temp gauge.
1. On the water pressure gauge: I have read several threads that say to tie the pressure tester into your tell-tale line. The problem: this older o/b doesn't have the tell tale. I think from reading the shop manual and watching it run on muffs (when I bought it) that water recirculates until the engine reaches operating temperature and then the T-stat opens and some water bleeds out the exhaust ports on the back of the engine (but its not a spray like the pee line from a tell tale)... So, any guidance where to install the pressure fitting on this type of outboard?
2. On the water temp: The manual says that there is a buzzer switch in the remote that will indicate excessive engine temps. However, I'd still like to have a gauge. Any guidance on where to attach the sender would be most appreciated...
Thanks very much for helping me out!!
P.S. I posted THIS THREAD when I acquired my project boat last summer... You guys were a big help with some of the initial check up.... (the boat restore is going well so far).
