Hello,
I'm hoping for some help here. I have an unusual situation. Let me try to explain this. I have a 1979 15 hp 2 stroke that I use as a kicker on a salmon boat. It is an electric start model with a charging stator. Last year I decided to put a throttle servo on it to controll trolling speed. After I installed it I found that the servo motor was chattering and doing things it shouldn't. I called the mfr. of the servo unit and they said my charging system was emitting an electrical "noise". We tried shielding cables to the servo and all sorts of trial and error things and got nowhere. I ended up taking the servo control off and went back to controlling the speed with the tiller handle. Now I get to looking around and I see over the years Johnson has made several styles of ignition systems on these engines and they for the most part wwill interchange. I bought a ignition/stator setup from an 89 (10 years newer) thinking maybe they changed the electronics end of this enough that it may be worth a shot at getting rid of my "noise". I changed it all over. Got rid of the power pack mounted to the back of the block and changed out the coils and all of that biz. I started it and it fired right up and runs like a champ but when I checked the voltage output on the charging side of it the thing has like 20 volts idling and increases up to like 55 volts if you rev it up at all. I changed out the rectifier with the old one and have the same thing. Is my charging stator bad or what am I missing here ??? PLEASE HELP!!!
Thanks
Thanks
