I have a 1970 25hp johnson seahorse that I have completely rebuilt. It is a strong running engine and idles smooth and easy. It is an easy starter, usually one or two cranks and were off. However when the temperature drops i need to use the choke pull to start it. However, this morning the black plastic pull broke in half. Now I have No way to pull the choke to enable it. I tried to epoxy it but it quickly failed. I find that the choke pull is a discontinued item and have looked all over the web. Where can I find this vintage part to once again make my engine complete? I don't want to rig up a wire like many have suggested. Any help??
