Bucks4life
- Oct 28, 2012
- 22
I'm a longtime boater, but not with an outboard. So, after purchasing a cheap pontoon for fishing with a 01' Johnson 9.9 I guess I'm a little bit in the dark.
When I first tried to start it, it wouldn't start. I pulled the cover off and took a quick look. Right where the gas line connects, there is small red lever. So, thinking this might be a fuel shut off I flipped it 180 degrees, but then figured out that gas line was backward and I'm pretty sure the thing wont start with out gas.
Anyway, I'm now under the impression that that little red lever is a manual choke bypass, or something like that. And now the motor will start but will only run on full manual choke and then die, with lots of white smoke. Anyway, I'm not a hundred percent sure what direction it was in when I flipped the lever, and without the owners manual, I'm not sure how to get the red lever back to it's original position to get the motor running at it's best. Any help with this would be greatly appreciated!
