Re: Wiring starter and solenoid on 150 oceanrunner
Big red cable from positive battery terminak goes to one of the large terminals on the solenoid. Other large terminal on solenoid goes to the starter. Battery negative goes to engine block. Smaller red wire from charging system goes on same solenoid terminal the positive battery cable is on. Small wire from "S" terminal on ignition switch goes to small terminal on solenoid.
