Shakedownscott
- Jul 12, 2011
- 179
I recently purchased a boat motor and trailer with the plan of fixing it up over the winter. The outboard is a 110 Hp Evinrude V4 VRO. I am having a hard time figuring out exactly what this motor is because the sticker on the transom clamp is missing. I am hoping that someone can help me identify it so I can get a manual for it.
I found what may be a serial number R82745890 on one of the freeze plugs in the block? Not sure if this is helpful. The guy that sold it to me said it was a '93 but I don't see a 110 Hp offered in '93 at least from the research I did. So far from looking at online parts manuals I think it may be from the '86-'89 erra.
When I looked at the boat I heard the engine run but it did not want to idle smootly. So far I checked spark and compression. The spark is good on all cylinders but has low compression on two cylinders. The two top cylinders have 95 annd 100 psi while the bottom two have 65 and 75 psi. I squirted some oil in the bottom cylinders and got them to 75 and 100 psi.
Is there any reason that would cause both lower cylinders to be low? I dont' want to rebuld the engine (if I get that far) to have this happen again.
The outboard is still using the VRO system which from what I have read ont his site looks like a bad idea. Not sure if this caused the problem but there is a lot of oil under the coweling, wondering if it has been leaking Vs oiling the motor.
Right now I am thinking to pull the head off of the worse side and look for scoring etc. Anything else I shoul check before removing the head?
Thanks for any advice.
