CumminsDriver
- Nov 25, 2012
- 24
Hey I'm getting ready to purchase a power pack in about a hr for my engine want to make sure that's what it is that, take a glimpse at my readings and tell me what you think just from my readings tell me what I need.. Everything on the engine is %100 has been completely gone through including cleaning all connections and grounds, rebuilt carb also...
Here's DVA voltage Readings:
Trigger is reading .6 to 1volt
Stator is reading 875 ohms with atleast 150volts maybe little more in the 140-170V range (ohms should be 450-550 is the stator messed up?)
Power pack has 2volts coming from orange wires that go to the coils they provide power to coils for them to spark.
from those 3 readings what do I need??
All obvious is done including by-passing the kill switch also I just want some one to look at these readings and tell me what it is
THANK YOU GUYS SO MUCH! I don't want to waste money on a 150 doller part please help me out
Here's the CDI diagrams to see what they should read..
http://www.cdielectronics.com/downloads/Johnson_Evinrude_DVA.pdf
(IF YOU NEED)
SERIAL:E30RLEDE
MODEL: G 04111131
(IF YOU NEED)
SERIAL:E30RLEDE
MODEL: G 04111131
