Noob here, I just got a 7.5 for free when i picked up a 14 ft jon boat off craigslist. I tried to pull the starter and it wont move. So far I have removed spark plugs, dropped lower end, and soaked cylinders with wd40 for 12 hours. Still nothing. Is there anything else simple to try that I am forgetting, or is my next step to take apart the engine?
Also, Should I keep trying to soak the cylinders for a few more days in hope that they will free up, and should i use something other than wd40? And is there anyway to ensure there is not an issue with the motor being in gear? I have tried to pull it in every throttle position.
