Trollstriper
- Nov 20, 2012
- 6
Looking for some help with my 1988 Johnson 50hp model # (J50TLCCS) not charging. To give you some idea of how i use the motor, we troll for striper at idle for hours, occasionally at wot from place to place, but mostly idle. The only load on the battery is a lowrance hds 7 with structure scan ,and it does have tilt and trim thus killing the battery that much quicker if i use it. In this situation the battery will last about 2/3 of the day and then wont turn motor over. i have done alot of searching on this forum reading different threads and done the Joe Reeves rectifier test which seem to pass so i dont know where to go from here. I also checked the voltage at battery, alone 12.50 volts, hooked up at idle never above 12.84 volts and 3000 rpm 13.00 volts. Checked for loose or broken wire found nothing. thinking maybe stator but dont know where to start to test it. any help would be appreciated. Thanks.
