pontoon781
- Nov 13, 2012
- 7
I am replacing all the gears, pinion, forward, reverse and clutch dog (bad pinion and clutch dog) I do not want to buy a 300$ one time use shim measurement tool nor pay the shop $150 to do it for me. (2 kids in college) My question is: Since the goal is minimum gear backlash, Can I just add or remove shims as per the backlash test. That would mean removing the drive shaft bearing carrier every time, but that?s no big deal.
The test being push down on the propshaft, pull up on the drive shaft and turn no more than 3/16? (as I understand it)
Thank you.
Thank you.
