The primer bulb on my 1995 115 HP Johnson cannot be squeezed it is very hard. I removed the primer bulb assembly from the oil tank but can't get the primer bulb to pump anything. The oil in the tank appears to be clean as well as the tank.It seems as though the line of the primer bulb is blocked. Can someone walk me through the proper way to get the primer bulb assembly to function? I have no idea why the line appears to be blocked or the reason why the primer bulb doesn't compress and pump oil from the open ended line. Is there a valve or is the float in the VRO malfunctioning? I am not sure how the float on the assembly is suppose to operate, there is only minimal movement up and down on the float. I am getting a warning horn going off after a short running of the engine.
Thanks in advance for your responses .
Loumo
Loumo
