Right off the bat let me admit that up until 2 months ago I had never worked on an outboard. I'm very much a novice but am trying to learn. I have a 10 hp 1959 Seahorse that I'm bringing back from the dead. The recoil starter seems a bit harder to pull than others I've seen on Youtube. The flywheel was stuck when I got it. I got it loose putting some oil in the cylinders. I rebuilt the carb and installed new condensers and points. Compression is 55 and 60. It'll start now, but runs rough. I still need to adjust the needles and I'm having tons of smoke from burning off the oil.
My question is whether the resistance from the crankshaft turning the rods and pushing the pistons up and down is sufficient to make pulling the rope kinda resistant and jerky. As the flywheel turns around it seems to hit a easy spot, which allows easier pulling on the rope, and then hits a very resistant section, which makes it hard to pull, all of which combined makes for a jerky full pull of the rope. Any suggestions on how to smooth things out? Is this a very normal condition? See video below. Thanks for any help.
1959 10hp Johnson outboard starter demo - YouTube
