I have continuous white smoke pouring out of this motor. It's not steam. The smoke lingers in the air for at least 5 minutes after the motor dies. It'd make a great Halloween fog machine! I had poured Marvel oil in the cylinders to free the pistons when I got this motor this summer. Worked great. Now that I got it running though, I'm wondering if this smoke is from the Marvel oil or from water in the cylinders. Doesn't burning oil make blue smoke? Also, the test barrel water looked like the Exxon Valdez had run aground in there. When I pulled the motor out of the tank I had all this brown water/oil residue gunk running down the sides like pancake syrup. Took 5 minutes to wipe it all off. Thanks for any help, you guys are terrific!
One more thing to note, somebody said in another forum post that a missing thermostat would make it smoke from incomplete combustion due to cooler temps in the cylinders. I have removed the thermostat, but I have so much smoke I can't believe it's just from that. It's enough smoke to make the neighbors think our house is on fire! I'll be replacing the thermostat and gasket soon regardless. I'll also post a video soon, as long as noone thinks running it again would damage the motor. Thanks again!
Edit: I realized I didn't really ask a question here. So, is tons of white smoke to be expected from pouring oil in the cylinders or do I have a water intrusion issue? How would I proceed if it's likely water in the cylinder? Thanks!
