Hey all, I need help diagnosing a problem I have been having with my Johnson 140 Looper.
It will start and run great sometimes, othertimes it will not start, and other times it will just bog down and die while running. I have noticed that when trying to start, if you place your hand in front of one of the carbs, you can feel blowback. From that same carb if you tilt the motor up, fuel comes out. I have checked the compression and all is good. I have also recently rebuilt the carbs. I have also noticed that when cold and it first fires up, it is only running on 2 cylinders for a second or two and then begins to fire on all 4.
I am currently away from the boat but will be returning home for a week and would like to get her up and running well again. any thoughts or places to really begin?
Thanks in advance!!
Thanks in advance!!
