hi!
I have a 2005 J10R4SOA Johnson (9.9hp, 4 strokes), tiller, rope start, bought from a friend of mine.
recently I had an issue with water in fuel so I checked fuel system and ignition (spark plugs).
I noticed very clear one yellow wire terminated with a connector inside an insulator, connected nowhere. I am not very sure but I remember something - that was an other wire, most probably black (not red because it came into attention) left in the air (isolated).
unfortunately I keep the boat and the engine far from home and I can not check sooner than 2 weeks.
my questions for you guys are:
is it possible to have the charging coil installed, without the rectifier?
is it installed by default but not wired?
I checked the service manual (I bought it from internet) but I can not identify in memory the rectifier. my friend does not know anything about charging system... he is far from a tech person...
thanks!
thanks!
