Re: 1964 Johnson super sea horse 75 hp
Hi Joe; still could use your help i had the water pump and had to put another impeller in. It does spit a little water now but not much. I ran it in a 40 gal can for about a half hour it not get hot what do you think is going on???? Thanks again for your time and help. Clark
You should stop and figure out how that thing works. So, stop and read this: That motor has a thermotat-controlled recirculating cooling system. The water pump sends water up to the powerhead through one water tube, and it circulates through the water jackets, then is presented to the thermostat. The 'stat takes its temperature, and if it is less than 140 degrees, it sends it back down the second water tube to the water pump, which recirculates it back to the powerhead. This goes on till the 'stat decides it is warm enough, then it opens and the water is discharged out the exhaust and the pump supplies more cool water from the lake and the whole process continues. Understand this: The process is going on constantly, with the 'stat opening and closing as often as needed to maintain a constant temperature.
The "tell tale" is that big blow-hole on the backside. When the 'stat is closed, only a bit of spray is discharged. (Some discharge is required to cool the exhaust housing). Now---when the motor is idleing, it may never get hot enough to open the thermostat because of that small discharge that is cooling the exhaust housing. That is perfectly normal. In gear and pushing a boat at low to moderate speed, the discharge may come and go. Hard flat-out running will heat it up enough to open the stat and keep it open till you slow down. It will never discharge water like a garden hose. It blows out at slow speeds and sort of flows out at high speeds.
Finally, I don't know what kind of hose adapter you are using. Whatever it is, you cannot test any water pump by running on a hose. The hose is supplying water under pressure to the pump, and it really doesn't have to function at all.
Get that thing on a boat on the lake and see if it does what I just described.
BTW, this is exactly how the cooling system works on your car except a radiator takes place of the lake and no water is discharged out the exhaust pipe. It is not new, unique, or unusual.
