I have this Johnson Sea-Horse I hear they aren't that great but that doesn't matter in this case. I'm including a picture to help describe what im talking about. Here goes... I have power coming from battery into Starter Relay 12.4 V, when key is turned i have Power on both small grey wire posts 12.4 V, I have Zero V coming from the the starter relay Which in turn will not turn over engine.
Things I have already Done
1.Cleaned and Checked all connections
2.Use jumper wires to act as grounds
3.used jumper wires to bypass starter relay it turns over.
4.Replaced starter relay with brand new one Same Result.
