Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
How to adjust "idle" on my 115 johnson
  • How to adjust "idle" on my 115 johnson
    I have a 1999 Johnson 115 Oceanrunner. It runs perfect, I love it. I just have a problem with the "idle" RPM's.
    I don't know what it should be but it is at 1000 rpms and I think it is too high. I have always had I/O's and kept their idle at about 550 to 600 rpms. What is the correct setting? And how do I adjust it?
    Re: How to adjust &quot;idle&quot; on my 115 johnson
    The idle should be around 600 in gear. Look in the sticky at the top of this forum for your particular motor.
    • #3
      Banner, I believe your motor's idle speed is set by idle timing. First check to see that the throttle cable closes the carbs all the way. If so, get a Service manual and double check idle and max timing.
      BTW - I once found a piece of wire from the voltage regulator was holding the timing a bit advanced. Had same symptoms you have.
      • #4
        I'm new to this forum. I don't know what or where the "sticky" is. Thanks for the rpm in gear setting.
        • #5
          Hi Chris1956: I'll check the throttle cable tomorrow. It could be out of sink. The shifter cable was W A Y O U T of sink and I corrected it (my first post). I fish Barnegat Bay, the inlet, and Barnegat Reef. Love the area.
          • #6
            I was referring to the Top Secret File at the top of the Johnson/Evinrude repair forum.
            • #7
              When you set the idle speed make sure the mtr is in the water for proper back pressure. Don't do it on muffs.
              • #8
                Also, the manual specifies idle speed with the engine in gear with the boat underway. On most engines idle speed should be between about 650 and 850 as I recall.
                Checkmate Rebuild: http://forums.iboats.com/forum/boat-...eckmate-eluder
                “Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
                ― Isaac Asimov
