First time ever putting a motor on..............have the motor mounted and steering hooked up....all my controls are connected to the motor, I will need to mount the throttle lever, going to need to run the cables through the inside gunnel and out of the transom boot, there is a large red colored rubber boot where the elctricals seem to be connected inside the motor, can I take this boot apart?? are the wires just plugged in together and held inside the boot? I will need to disconnect it from the motor to get it in the gunnel and ran through the transom cable boot, also any advice on removing the throttle and shift cable as these also will go through the transom cable boot into the gunnel and attached to the throttle lever......................I greatly appreciate any guidance on this!
Motor is a 1994 50HP Johnson
