Hi there, I have a 1988 Evinrude 140 V4 and have been trying to set up the gearbox control cable but can?t seem to be able to get it to work correctly. I have adjusted the cable by placing the control lever in the neutral position then loosening off the jam-nut on the cable adjuster. I can either extend or collapse the adjuster until the shift arm on the engine is in the neutral position or very close to it. The problem is that when I push the control to the "Forward idle" position it seems to stop short or will only just engage the gears, this is the same for the "Reverse idle" position. I can adjust the cable slightly to one side of the neutral position and the gearbox will engage in either forward or reverse depending on which side of the neutral I have adjusted it but I can seem to get it to a position where it will go into both Forward and Reverse. I am thinking there may be some general wear and backlash in the motor linkages but am not really sure. Is there anything that I am missing or anyway of making further adjustments? Thanks in advance for any help offered. Mike
