Hi Everyone,
I recently purchased another lower unit for my motor, an 81 70hp evinrude (btw an 84 lower unit is a perfect fit for an 81) because my drive shaft was broken on the top where the splines are. When I went to put on the new lower unit, I realized that a little piece of the old drive shaft is still stuck up in where the splines fit to the upper portion of the motor.
Does anyone know how to get this out? I tried hitting it with some other medal rods, but it seems to be stuck in there pretty good. My guess is there is about half an inch of the tip of the old drive shaft stuck up there.
Is there an easier way to get this out, other than drilling it, or trying to weld something to it and pull it out??
If I start it up and get the flywheel to spin, will this dislodge this?
Please help!!!
Thanks!
Please help!!!
Thanks!
