Hello all,
I am new to the forums and wanted to post some issues i'm having with my motor.
First off, as the title says, it's a 1993 Evinrude 40hp (not certain of the model number) I purchased the boat about a month ago. The issues I am having consist of;
When running the boat (regardless of throttle position) it sounds like it's bogging down. For example at WOT, it will only hit 3k RPM. I had put stable in the gas because I wasnt sure if the previous owner had any maintence or has taken any precaution to treating ethonol, etc. When I am @ 3k RPM if I push the choke several times the motor wakes up and will hit 6k but I have to keep doing that (which cant be good for the engine, so I don't do it often) I for whatever reason I was out one day and I went out and the motor ran perfect, it wouldnt bog down, it acclerated flawlessly, all together it ran great. That was short lived through, it's back to running like crap. As for gas/oil mixture, i'm running a 50:1 mixture as reccomended. Starting this engine isnt an issue at all it fires up first time regardless if it has been sitting for 1 day or 1 week. I had a buddy sit back where the "fuel bubble" is and at WOT I asked him to pump to force more fuel into the engine to see if it could be a fuel problem? That has no effect. Also last time out when running WOT when it sits at 3k rpm by me hitting the choke, it didnt do much (usually it will get me to about 5-6k now it jumped maybe to 3200 rmp (I hope I didnt ruin anything) My question is what could be wrong? Fuel pump, Carb(s), Spark, other? I don't really want to take it to the boat shop and get banged up on a thousand dollar bill. I have worked on 2 stroke before (dirtbikes and four wheelers) but never anything marine and to be honest it seems a bit intimidating. Sorry for the rant, I'm just trying to provide as much info as possible on this issue to help you all understand what's going on. I have read previous threads to see if I could find a similar issue but didn't really find anything.
Thanks in advanced!
Thanks in advanced!
