jrdplowing
- Aug 28, 2011
- 35
i have a problem and not shure why this is leaking, but the rear mounting bolt hole for the pull start assembly has just recently stripped out on me and is leaking water from the bolt hole, if i heli-coil this hole will it also stop leaking or is there another problem, also keeps closing the gap on lower cylinder spark plug, thinking conn rod problem, any info would be appreciated,thanks,JRD
