Hi i have recently aquired a johnson 55 hp engine to cut a long story short thought we had got all electrics sorted started first time sounded sweet water coming out the tell tale but when i went to switch engine off it wouldnt switch off so disconnected wires in between the two coils so now im thinking this is where the kill switch should be fitted .So reconnected these two wires just to start engine again and got no spark at all checked all wiring exactly the same as when it first started if any ideas would be great to hear from anyone thanks gary
