Re: 1959 Johnson 50 hp v4 magneto/spark issue
Well, I tried unplugging one plug while it was running and it sure ran rough, so I really think the issue is with the tach and not the motor. That is too bad really. I got the thing mainly because of a higher speed miss or cutout. I thought it would help setting the jets if that was the problem. It still cut out so I checked all 4 wires and observed the discrepancy of the tach reading the left and right cylinder rpms. Now the motor runs smooth and responds well in a trash can full of water, but it has done that before. I am at a loss here. The carbs and jets are clean. No leaks in the fuel system. Sure seems to use plenty of fuel! lol. What am I missing? What is a main reson for cutting out at higher rpms? The tach will help in setting the jets as it will read good enough to notice a rise or decline in rpms of a single plug. But even getting the jets fairly close to optimum had no effect on wot. I know it's not the best engine, but up till wot it is smooth and strong as a bull.
Thanks guys. I don't know why the fast tach would read like that, but it sure threw me off. I really don't think that the problem is with the mag now. But all the checks I did of the mag, and insulating the coil most likely helped. It sure didn't hurt, as now the mag is about as good as a 54 year old used mag will ever be! Great site. Lots of info here that would be difficult if not impossible to find elsewhere.
