Have a 1970 Eviunrude 60 HP New impeller has been installed (correctly) seals and water pump, pump housing all in good shape....thermostat has been checked looks new...all lines have been checked for blockage...cannot get the motor to pump water.....motor starts and runs fine , spark plugs were pulled after running to make sure water not in the cylinder all good..water is getting to the thermostat..can anyone help as to what to look for or a solution. greatly appreciate any advice! (the lower unit was taken off three times to double check that everything is put together correctly)
Thank You
Thank You
