Good morning to you all. My name is Daniel and I'm writing from Italy. I am a happy owner of an outboard EVINRUDE 250 FICHT RAM 2003. But now I have some problems: after about 25-30 minutes the engine suddenly turns off by itself. No sound or visual signal from the tachometer. I tried to replace the tachometer to see if it was a problem but the tachometer is off again without leaving a light on or beep. 5 minutes after the engine starts normally. I noticed, however, that the relay (5 pin) located behind the unit EMM sometimes did not work and bridging the two wires of the engine was restarted. Unfortunately, sometimes this is not enough even bypassing the relay and in this case I had to wait 5-10 minutes after the engine is restarted. I want to specify that the units EMM is never hot and the cooling circuit of the same functions properly. I noticed that the problem occurs when i increase speed or when I decrease it. Could it be an electrical problem related to the lever command? :facepalm: thanks to all those who are able to give me a hint before making a full diagnosis at a service center EVINRUDE BRP.
Daniele
Daniele
