hall832
- Sep 6, 2012
- 234
1985 Johnson 150 has new coils, new power pack. Carbs are rebuilt. When I run it up not in gear its fine. I put it under a load and it idles perfect but whem i bring it up past 1400 rpms there is a definte miss. then when i get past 2100-200 rpms its fine(no miss) gets up to 4800 rpms. Thats it WOT. Prop is correct. Not sure if its stator or timer base. Compression is within of 5 of each cylinder. I know i need a peak meter. I have ordered it. I just was wondering if you can tell me what you think. going crazy.
