Hi,
I bought a 3hp evinrude and new coils, points, capcitors. It runs now, but not smooth. Sometimes for 5 minutes, sometimes for 2. And the first time for almost 10 minutes or so. It turns very hot, and I'm affraid that's why it turns of. When I splash water against the cylinder head it instantly boils. The last time I started it, the revs are going up and down, up and down, etc, till the engine stops. I've opened the exhaust cover and it looked fine there, everything clean. The carb is clean as well. So now I have the following questions:
- To save time and money, where should I start checking the motor? I'm not from the USA, spare parts are 3 times more expensive here.
- How can I determine if the impeller is fine? I don't know if it is ever replaced, since I just purchased the motor.
Many thanks in advance!
