Re: 1976 Johnson 55HP Carb Jet
Thanks for all the help. Heres a update on the motor, I pulled the carbs and cleaned them.....everything that could be cleaned has been cleaned. The bottom carb was pretty bad, the High Speed Main Jet was pretty much blocked in. Had to scrape the crud away the even get to it to clean it. Top carb was pretty much spotless.
Re-installed the carbs, hooked everything back up and started the motor. It was still a little hard to start from cold, but once it got warm I checked the timing. It was set right at TDC, so I adjusted it to 4 Degrees BTDC like the manual says. Then re-adjusted all the linkages to take the slack out. Last I made sure the carb roller was touching the cam...with the butterfly valves all the way closed.
It ran well, but when you put it in gear it sounded like it was barely idling...like about to cut off. I let it run like that til it did. I let it sit for about 30 minutes and to get it to start I had to hit the choke...get it to fire...then give it gas with the warm up lever to get it run...at that point it would die even at idle not in gear.
I adjusted the carbs about 1/16th turn richer than what they were set at when I took them apart, the motor seems to idle better, and the RPM's barely drop now when put in gear. Itll idle forever at dead idle right now. I just let it sit for about 20 minutes, went back out, hit the key and it started right up.
If I had to assume, I would think it was combination of dirty carbs, bad timing and lean carbs......does this sound right?
