Just want to make sure that I have the correct wires connected to the spark plugs from coils.
Standing on the ground & off the boat, looking forward at the back of the engine:
The right & left sides of engine has upper & lower coils.
The top "right side" of the coil spark plug wire is connected to, I believe, the #1 cylinder spark plug.
The bottom "right side" of the coil spark plug wire is connected to, I believe, the #3 cylinder spark plug.
The top "left side" coil of the spark plug wire is connected to, I believe, the #2 cylinder spark plug.
The bottom "left side" coil of the spark plug wire is connected to, I believe, the #4 cylinder spark plug.
Can someone tell me if this correct?
Thanks in advance
Thanks in advance
