LindenLongRods
- Jul 10, 2007
- 192
I have my lower unit off to the change water pump but it looks ok, impellor looks fine, should it just lift off also? seems stuck, just a lots of sand (I was in the Shallows of Barnegat Bay) Should I change or just clean? Gaskets are stretched a little. also housing for shift rod is stuck tight I wanna get a look inside. It should just lift off after bolts are off right?, should I or not go into shift rod housing? It was very tight to shift before I took off lower unit. Engine is a 1987 Johnson 88 SPL
