Nailknot85
- Aug 21, 2012
- 4
Hello everyone newby to the site here. I have a few questions about carb tuning on an old johnson 6 horse outboard, model CD-24D, not sure on carb specifics at the moment though since I am away from home, is there more than one carb available for these motors?
TL;DR: I need base settings for a carb with the low speed needle/seat removed.
I decided it would be a good idea to take the old girl apart for some winter maintenance last winter, last time I took 'er out it took a lot of grunting to get a start, pretty good though for having sat in the back of a shed for two years.
My carb only has a high speed needle, the low speed needle and seat are blocked off with a bolt, this is confounding me as far as base settings go because the maintenance manual I have gives base settings for high speed and low speed needles.
I made the mistake of not recording the current needle settings on tear down and low and behold using the base settings in the manual result in no startey startey. At first I thought it was a fuel pump problem but after moving the diaphragm spring to the proper position I get fuel squirting out of its outlet pretty reliably.
The only way I have been able to get the motor to run is by completely removing the mixture needle leaving a gaping hole in its place, this has resulted in a running motor for anywhere between 1 and 5 minutes, after that it slowly bogs down and dies.
I will admit that I haven't devoted that much time to it since being disappointed 6 months ago, this and the leaky LU I caused kind of let the wind out of my sails.
Anyhow thanks for reading, hopefully there's an old guru out there who can help me sort this out.
