73 25hp evinrude carb cleaning
fireman57
Re: 73 25hp evinrude carb cleaning
Welcome to iboats. Take it off and soak it overnight in a good carb cleaner. run a small wire through all the orafices and jets then blow it out with compressed air and you should be good to go.
lindy46
You have to take it apart to clean it properly. As long as it's apart, I'd get a rebuild kit and install new components.
