1997 evinrude 115 intruder 60 degree motor
i have had an ongoing issue with my evinrude. boat starts up fine, but will not idle for more then 10 seconds during those 10 seconds the idle is at about 750-800 tops.
I have drained the fuel and added an inline fuel filter, same issue.
i checked compression and all cylinders are at between 90 and 93.
i checked spark, all have a strong blue spark.
I pulled the thermostats out of the engine today, they are enclosed in plastic. I am fairly easily able to blow through one, the other is almost impossible. I have heard that thermostats sticking one way or the other can cause some symptoms i describe.
I am unsure how my thermostats should respond as ive never dealt with these enclosed types before.
Can thermostat issues cause the rough idle? what should the compression be for my motor? and what other things should i check. Thank you to anyone who can answer these questions for me.
p.s. i had started a thread about spark plugs that i was updating with new findings. thought i would make a new thread to describe my new issues as spark plugs doesnt seem to be an issue.
