Re: 1964 Evinrude 9.9hp dies when I put the motor cover back on
You most likey have an exh leak thats choking out your motor. Its a problem on the 9.5`s. Could be shift shaft seal, clam shell doughnut, ect. Some people will drill holes in there cover to help if you don`t want to fix the leak.
