Just rebuilt carburetors, reinstalled and when started in neutral, runs at 1000RPM?s then after 5 seconds or so, runs to 3000RPM?s. Shut engine down immediately. Tested a few times with the same result. Sometimes it even starts up at 3000RPM?s.
Checked float level, checked needle for sticking, re-checked all hoses, even solenoid assembly.
Is there anything else I can do?
