Good evening all,
I have an 1996 3cyl. Johnson 25hp with model number J25RMLED which has a stripped steering friction screw. A bolt was used in it's place which didn't belong so the hole was bored a size even bigger than what it should have been. I also have a feeling that the shaft/bushing inside is damaged as the tip of the bolt is all rounded.
Any help is appreciated. I am quite fond of the motor has it has sentimental value. I would like it fixed good as new. Currently it is in a shop but I am afraid that it won't be properly fixed so I would like your advice on what I should look for.
Thanks in advance!
Simon
Thanks in advance!
Simon
