15hp on a light 12ft boat will not rev up and reach WOT RPM
1977 Evinrude 15hp 15704m Bought on Craigslist for $120 I Had fix recoil starter, tiller handle and kill switch. Compression test 100-110psi both cyl. Rebuilt and cleaned the carb two times. New thermostat, New Head gasket. New spark plugs. New fuel lines. New prop Solas 9.25x10. Set the timming, Had to set throttle cam all the way out so throttle shaft will just start to move when roller is in line with mark on cam. Throttle roller sits in small notch on throttle cam at wot and timing plate turns all the way to the stop. At wot the looking in to carb throttle plate is open 90% of the way. The throttle plate is NOT flat 100% but more like 90% open almost flat... Is this normal? I checked and have the correct carb, throttle cam and throttle roller. Even if the throttle was only open 90% I should get much better performance.
Boat is a 12ft Semi-V Aluminum Starcraft weighs 130lbs 12ft long 48inch wide at transom top. I weigh 170lbs Two Batteries 80lbs. trolling motor 25lbs. Evinrude 75lbs. Trim set all the way down. Both batteries strapped to front seat
I can not get the engine to to WOT rpm even with the light boat and just what is listed above for weight. The highest rpm I can get is 4800rpm at 15mph GPS. I can tell the engine wil not rev up like it should. If I have a second person in the boat (170lbs) I get 11mph
If i apply a bit of choke it bogs down, If i spray some wd40 in to carb it bogs. If i pull either plug wire it runs very poorly. squeezing primer makes no difference. Run with engine cover off no change.
I should be able to get 6000rpm from this set up and i think around 20mph even with two people in boat. If you have any ideas of what could be wrong or what to check please let me know. I have done lots of searching, manual reading and reading leeroysramblings.
Thanks for any help!
