Re: 1977 johnson 70 hp, shifting rod? instalation help
undo the shifting rod connection below the starter undo the bolts what ever contraption you, ve got on , screw the 70hp shifting rod into your gear box line the drive shaft & gear rod up in the leg & reconect the rod with the leaver under the carb
