OK what should I run this rebuilt engine at ???? I was told to prop for 5800 rpm because this engine is high performance and higher rpm will keep carbon build up to a minimum BUT my manual says 4500-5500....what would you prop for .thanks
5800 is a good number to shoot for, light load conditions. When you do load down with people & gear you'll be at the high end of your recommended range.
