Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Need Help Asap No Spark 1980 Evinrude 70 H.P
  • Need Help Asap No Spark 1980 Evinrude 70 H.P
    Ok hi my name is alex i am new to this forum but have own only evinrude engines all being 70-80's model 3 cylinders.I now have a 1980 evinrude 70 hp on the back of my trihull that i just bought off a fellow. I have ran a compression check before purchase all cylinders +- 2 psi. I also removed a 1982 evinrude 75 h.p with all new ignition due to low compression on 2nd rebuild. I have since swapped the power pack/ stator/ timer base and voltage regulator with known good parts majority being brand new. i have also performed the kill switch delete test to no avail. I am at a lost here and have no idea how i still have no spark when i had a+ spark on my old engine. Only thing left on old motor that i could swap is coils which would make no sence on why i have no spark on all cylinders and the harness. Any help would be very appreciated.
    Re: Need Help Asap No Spark 1980 Evinrude 70 H.P
    Go to the CDI website and look up your engine, use their troubleshooting guide to help you find your problem.
    • #3
      I will run through tomarrow . Will the timer base gap cause a no spark situation
      • #4
        Yes, it can.
        Please no PMs. My mailbox is full anyway......
