Hello,
i am new to forum so please excuse me if i make any mistakes. I am the original owner of 1989 evinrude 25 hp. I am trying to replace water pump, (first time) and am following manual and instructions with new water pump. Yesterday, i started to remove gearcase connector, however, top nut (upper gearcase connector) will not slide up towards the crankcase after removal from bottom gearcase connector. It is completely disconnected as far as i can see. I also do not see a plastic keeper. Removed the 4 bolts and 1 nut and tried sliding gearcase down off muffler housing. It was really stubborn at first, however, it slide out/down approximately 1" and will not go any further. I cannot figure out what is keeping upper gearcase connector from sliding up shaft and why gearcase will not separate from muffler housing. I tried sliding gearcase back up toward the housing, however, will not move. Any help would be very much appreciated. Thanks in advance.
