Kevin60181
- Jun 30, 2012
- 44
I just gave this 1956 Evinrude 15HP outboard engine a complete tune up, coils, wires, plugs, points, etc. Along with new seals, O-rings in the lower gear case and a complete new water pump.
I did grease up the O-rings, Seals, and gear shifter control arm linkage before & during install.
So some of that grease could be from that. But would water be coming out there?
Here?s a short video I posted on You Tube of this problem:
http://youtu.be/5SzndO7aKkQ
Open to your ideas and suggestions!
Thank you in advance.
