Re: Timing base shake movement, 1956 Evinrude 15HP
Weebles wobble, but they don't fall down! LOL
I got your back 100% on this Armature Plate. Different posts & people call it different names. I know stator wasn't even close, cause they are wire windings. Armature??? May be.
I personally like Timing Plate, because it has the main timing marks on it.
or we could call it the points, coil and condenser dish. Seeing it’s plate like in shape & size and the dish is full of the above.
Being an election year, lets vote on this!
OK back to business.......
Yes! The coils where replaced. Twice, I pulled the big heavy thing located under the rope pull off the engine and moved the coils back thinking that the Flywheel was hitting hitting the coils now & then, during the up & down movement and making a loud clunk noise. (Noted on another post I placed - problem there was a lean sneeze) So the coils are as far back as they can be from the magnets. I will re-a-just the coils after I attempt the fix on the brass support ring.
I did remove that brass support ring so I could do a good cleaning before the tune-up. What a mess down there. Loaded with dirt, rust, oil and gunk. I gave it a light coat of grease along with the ring under it that the timing base screws into.
By the way, I use caliper grease that’s for brakes. It with stands high heat, resists water & dust, and has graphite in it. ONLY on external engine parts!!! If it rubs, slides, rotates or moves, I grease it after a good cleaning.
I did a search for joe's post with no luck.
I did find this post
http://forums.iboats.com/showthread.php?t=186387&highlight=support+ring
He noted that the aluminum retaining ring goes flat side up. Ahhh!
I do believe mine was tapperd side was facing up. That could be the problem!!!
Here's another post on Wobbly armature plate :
http://forums.iboats.com/showthread.php?t=390549&highlight=support+ring
Here's one Armature plate wiggle:
http://forums.iboats.com/showthread.php?t=90303&highlight=support+ring
Here's flywheel rubbing on timing plate:
http://forums.iboats.com/showthread.php?t=172758&highlight=support+ring
It’s 10:45PM and I have to be up at 4:30 am…. Sleepy eyes need to be fresh for the jail.
I hope to get at this after work on Monday. Busy the next 2 days.
Thank you again for all your help!
