Maxum21
- Mar 8, 2005
- 219
Took my "new to me" boat out today for the first time. Seemed to run good, idled good, got on plane decently, but from 3/4 throttle to wot it wouldnt advance past 4500 rpm's. actually from 3/4 to full thottle it hardly did anything but gain a mph. Seemed very sluggish in that throttle range. Boat is a '98 18' Larson weighing in @ 1650 lbs and the motor is a '96 johnson 115. I ran it w/ 3 other friends aboard. My prop is a ss 13.25x19 in decent shape.no gouges/badly bent blades or anything. i was told that prop should be in the ballpark for this motor. With 4 people on, boat ran 4500 rpms @ 35 mph with a clean hull(no bottom paint) but i'm off about a 1000 rpms. Where should i go from here? start messing with props or look at the motor first? thankyou!!
