Hello the other day i turned my boat on and it started fine. Then the next day i went to start it again and nothing happens. I try to use the tilt and trim on the motor and that does not work as well. I already check the battery and it is fine. I also got a test light to see if there was power to the starter and there is. Does anyone know what it might be ?
