narrowfarm
- May 28, 2011
- 45
Hello i bought an evinrude 1973 9.5hp that was all apart.
I put the engine together and lower unit back on,cleaned the carb ,cleaned the points and the engine now runs great!!I am getting a new head gasket,water pump and thermostat for the ebgine.
My issuse is how to set the shifting. It now will shift from neutral to reverse but not neutal to forward.The engine is in neutral at the Forward position and when i push up alittle bit to Reverse,the lever than is in the neutral position and the engine goes into reverse! It just seems that the linkage needs adjusting so i can get the Lever to move to the proper position.Any help here?? thanks john
