TrickyRicky
- Jul 17, 2012
- 37
Bought a non running Evinrude 4hp 1998
Took apart carb cleaned it out good
Found a orange cylinder shaped tube ( Bladder fuel pump # 0324661) on the fuel inlet side of carburetor bowl
It has a small cut (puncture) in the side of it
What is that Bladder supposed to do?
This engine has the onboard tank and external tank hook up
After playing with the adjustments I got it to run decent in a bucket
Starts 1 pull hot within a couple minutes if you let it cool for 20 minutes it seems flooded as it will only crank with throttle wide open. This is running on the onboard tank
